I erceive the following error when trying to copy an element:
cannot execute [object Object]: maximum call stack size exceeded.
I am thankful for any help.
Best regards,
Vouria
Best regards,
Vouria
@user117 - Could you please share a link to your project and if you know which specific element is triggering the error message?
@wonder.da - can you please share your project name and the steps taken that resulted in the error?
Hi. Did you soved this problam? I have same. Vhen a devide the scheme to two pages. It was ok.
Hi @pospjir, Can you share your project name and any error message you received?
Thanks.
Curtis
Hi Curtis
Here it is. If you select the schematic, you will see an error message.
Another problem I had when exporting the schematic to PDF. I had to split the schematic into two pages to be able to export it.
Thanks for the advice.
Otherwise the program is simple and quite functional.
https://www.digikey.cz/schemeit/project/el-deska-2025-12-20-1446-dcdad2a19306459ba8e8790d4ce73db8
út 23. 12. 2025 v 14:32 odesílatel Curtis_Johnson via DigiKey TechForum - An Electronic Component and Engineering Solution Forum <notifications@digikey.discoursemail.com> napsal:
