I followed the tutorial at Digilent Arty A7 with Xilinx Artix-7 Implementing SiFive FE310 RISC-V
But I’m facing the following error while executing:
make BSP=metal PROGRAM=hello TARGET=freedom-e310-arty upload
Open On-Chip Debugger 0.10.0+dev (SiFive OpenOCD 0.10.0-2019.08.2)
Licensed under GNU GPL v2
For bug reports:
Issues · sifive/freedom-tools · GitHub
adapter speed: 10000 kHz
Using JTAG
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select ’.
Info : ftdi: if you experience problems at higher adapter clocks, try the command “ftdi_tdo_sample_edge falling”
Info : clock speed 10000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: riscv.cpu: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Unsupported DTM version: 15
Info : Listening on port 3333 for gdb connections
Error: Target not examined yet
Any help would be appreciated.
Thanks.
Hi @alsartor , i made some edits to that page to help fix things, but i’m still getting the same error:
voodoo@debian-devbox:/opt/Digilent/freedom-e-sdk$ make BSP=metal PROGRAM=hello TARGET=freedom-e310-arty upload
scripts/upload --elf /opt/Digilent/freedom-e-sdk/software/hello/debug/hello.elf --openocd /opt/Digilent/riscv-openocd-0.10.0-2019.08.2-x86_64-linux-ubuntu14/bin/openocd --gdb /opt/Digilent/riscv64-unknown-elf-gcc-8.3.0-2019.08.0-x86_64-linux-ubuntu14/bin/riscv64-unknown-elf-gdb --openocd-config bsp/freedom-e310-arty/openocd.cfg
For bug reports:
https://github.com/sifive/freedom-tools/issues
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Error: Trying to use configured scan chain anyway...
localhost:3333: Connection timed out.
"monitor" command not supported by this target.
You can't do that when your target is `exec'
I’ll keep working on it, but this might be related:
PS, double check your pins…
Regards,
Hi @RobertCNelson, any update on this issue? Pins are set following the documentation. Thanks.
