FAQ: Can I order or request a specific LED bin?
No. DigiKey only offers such products at the level of granularity represented by the manufacturer’s published ordering codes.
To appreciate why, consider P/N 160-1448-1-ND as an example. Page 5 of the datasheet shows that the bin code is made up of two options for forward voltage, four options for luminous intensity, and 5 options for hue, resulting in 2x4x5= 40 different possible bin codes.
The various bin codes arise from natural variability in the production process, and if each is equally likely then supporting arbitrary bin code requests would require product to be produced and inventoried in quantities 40 times greater than the maximum order quantity to be supported. Viewed differently, offering devices at the level of individual bin codes would require the price to be roughly 40 times higher.
The economic impracticality of this should be apparent.
Bin code information is offered as a courtesy to help users cope with production variability, for example by adjusting a series resistor value at assembly to achieve uniformity of brightness. Typical industry practice is to ship only one bin code per reel of product in order to support such efforts.
While some manufacturers may support multiple ordering codes for high-volume product lines that specify limited sub-groups of available bin codes, the general case is that requests for specific bins or large volumes of the same bin cannot be honored.
Click here to return to the FAQ index.
