FDA-17251QBHT4F fan mounting
------Question for FDA2-17251QBHT4F Please Put your question below------
We need a fan meeting these specifications however no frame is required.
The original is mounted to an enclosure with two screws . Does this fan have two threaded holes on the back of the motor? Is a complete drawing or photo available?
Hello @troya
As per shown in datasheet, the FDA2‑17251QBHT4F fan does not have threaded holes on the back of the motor. Mounting is accomplished using the M4 mounting holes in the frame,
You can also check the 3D file here. https://qualtekusa.com/wp-content/uploads/3d/FDA2-17251.stp
