Hi DigiKey,
Do you guys have any of the following connectors in stock so I can order:
- TNC male to BNC female
- BNC male to PL259 Female
- TNC male to BNC Male
- BNC male to BNC male
- BNC female to PL259 female
Hi DigiKey,
Hello @Aaliyan
Welcome to the Community!
You can find the connectors here and select the appropriate part by applying the available filters.
Coaxial Connector (RF) Assemblies | Connectors, Interconnects | DigiKey
The reference above is for individual connectors, and would be the place to look if building one’s own custom cables.
One would look under “cable assemblies” if seeking pre-assembled cables, or under “adapters” for items that simply change connector formats.
Using “coaxial” as a search term should see these floating to the top of the “top results.”
Also, note that PL259/SO239 connectors are called “UHF” on the DigiKey site.
