Hello all,
Does anyone know a flat ribbon cable for this male PCB connector 98414-S06-10ULF? It is a 10 lines flat ribbon cable for 2x5 2mm pitch connector. I saw 90311-010LF a crimp cable connector, but I did not see any commercial cable for those PCB connectors
Thank you in advance
Hello Sergio,
I looked through the data sheet of this connector and found that the 98414-S06-10ULF does not have a mating connector that accepts flat ribbon cables, and the 98414-S06-10ULF itself is not meant for a cable connection but for PCB mounting. It will accept the mating connectors of 90311-010LF and 69307-010LF that attach to discrete cables which have to be crimped onto the terminals that would go inside those housings.
If you’re looking for a connector that accepts a 10 conductor flat ribbon cable, and that is through hole PCB mount similar to 98414-S06-10ULF, take a look at 2057-FTR-10-T-ND. It does have a different pitch though of 2.54mm.
