Trying to identify connector needed for ribbon cable neato D7
I broke the connector on the ribbon cable when I removed it. Supposedly this is a 20-pin ribbon cable. I have included the picture before I removed it from the mother board. I have also included a picture of the ribbon cable. Please help! Thanks! Vicki
Hello Vicki!
Welcome to The TechForum!
Are you able to determine the pitch of the contacts on the ribbon cable? I would be able to locate some possible alternate connectors if I knew what the pitch is on that cable. If you aren’t quite sure what pitch is, take a look at this post linked below:
@txdobergirl Did you ever figure this out? I’m in the same predicament.
Hello @jtst,
Could you measure the pitch or the overall width of the ribbon cable? For information on how to measure, please see this post-
To see the options we have in our system, please go to this link: Flat Flex Ribbon Jumpers, Cables | Electronic Components Distributor DigiKey
Thank you!
-Jeff
