FPC connector receptacle selection with footprint compactable
We require one FPC connector receptacle with 16 pin, 0.5mm pitch, bottom contact, Right angled , SMD type. This connector should satisfy the footprint compatibility as mentioned in the below picture.
Please check the availability of this connector.
Welcome to the forum.
The drawing looks like it’s from a data sheet.
If it is and you let us know the manufacturer and part number, it will be a hundred times easier locating compatible substitute parts.
