The following is for informational purposes only. Please verify that the specifications meet your requirement and check the manufacturer’s datasheet before using any product as a replacement.
FPS80-2405S was a power supply originally manufactured by Foresight Electronics. The hard data is difficult to track down online for this unit, but from the part numbering and information from customers who previously used it we can at least confirm the following specs:
Output1: 24V, 4A
Output2: 5V, 1A
Input: 100-250VAC, 3A
Based on these, it seems our best option in stock is part number RID-125-2405-ND from MEAN WELL USA. I don’t consider this a direct cross but it will at least hit the power requirements that were met by the original part number. Hope this helps!
