------Question for 6004 Please Put your question below------
Please tell me the diameter of the head of this screw.
I sent a request to the warehouse to see if we can measure it.
The head diameter measured was 5.5mm. Hope that helps!
Be aware that Sepac almost certainly doesn’t make these screws themselves. So other production lots will vary within the tolerances in the standard for #4 pan head sheet metal screws.
Thank you so much for checking for me.
The screws I need fit into a very small slot. They hold injection-molded plastic parts together.
The heads need to be 4mm to fit.
Thanks again. I really do appreciate it.
