Hello all,
I have and equipment and the surface mounted AC/DC converter seems to be dead. It is a 85-250VAC in
and 5VDC 0.5A out. The pin configuration is all in line (not in each corner like I found on digikey).
I am having difficulty finding documentation for the part number given, or something that would appear to be a potential drop-in replacement for the item pictured.
If available space permits, it may be possible to adapt an item such as RAC03-05SK to meet the need.
