Help Identify a Part
Need help identifying this part
It’s a self centering switch with an up/down function
-boom control switch on a 1074 Rogator sprayer
has 0310 stamped on it
bottom blue switches in image
Thx!
Hello @ridgecreekfarmsinc,
Thank you for your post.
With that piece, I believe it is either going to be a momentary toggle switch or it could possibly be a joystick itself.
I had better luck looking at toggle switches that are momentary in either direction and then spring back to the middle position which is Off.
There are a few parameters that I was not able to find that you will need to take a look at and decide if any of these options work.
Mom-Off-Mom Toggle Switches | Electronic Components Distributor DigiKey
After closer examination I found some part numbers between the switches:
OTTO 21649
T3-40013 0624
On Off On
Looks like you have T3-4 and T3-5 switches from OTTO.
T3 Commercial and Military Miniature Toggle Switch Supplier– OTTO Controls
Unfortunately I’m not seeing that we have an equivalent to these.
