Help identify part by marking code
Hi, I need help identifying two chips AWG and G3 1A. if you know ?
Hello Jamesyn81,
Part marking AWG looks to be for part number TPS3803-01DCKR.
Datasheet
Part marking 1A may be more difficult to identify as there are many parts with this. It is hard to tell from the photo but how many pins was this? Looked like 5pins. Did you have any ideas regarding the function of the IC?
Example BU4341FVE-TR
IC SUPERVISOR 1 CHANNEL 5VSOF
Datasheet
Some parts identified by the 1A marking code. Marking of electronic components, SMD Codes 1A, 1A **, 1A-, 1A1, 1A18, 1A20, 1A25, 1A30, 1A35, 1A4, 1A40, 1A45, 1A50, 1A55, 1A60, 1A=***, 1AM, 1AW, 1Ap, 1At. Datasheets BC846A, BC846AT, BC846AW, DAN202UM, FMMT3904, IRLML2402, KST3904, MMBT3904, MMBT3904LT1, MT501, RT9169-26GB, ZXTN25020DFLTA, ZXTN25040DFH.
Part Marking with 1A have 6pin. I don’t have any ideas of the chip. due to i can’t tested. Thank u
