This connector is on a laptop and is used to connect to a SATA hard drive with a flat flex cable to the motherboard, the latch is broken. The ruler for size measurements is in centimeters. It has 14 pins. Any help is appreciated.
so my guess is you need a FFC connector https://www.digikey.com/en/products/filter/ffc-fpc-flat-flexible-connectors/399?s=N4IgjCBcoBw1oDGUBmBDANgZwKYBoQB7KAbRAE4AmAVipAF0CAHAFyhAGUWAnASwDsA5iAC%2BIgpVLgALAAJEhfv1koUyeiKA
I not sure the pitch you are looking for
According to that ruler, my guess would be 0.5mm.
