HELP Identifying 8 Pin Connector
Hello All,
I have an SPOD and I destroyed the 8 pin connector. It looks like a molex, but it is a bit different looking and I can’t find the part anywhere. Does anyone have an idea of what plug this might be, or what direction I should look.
Add imagesScreen Shot 2021-02-26 at 9.08.20 AM Screen Shot 2021-02-26 at 9.00.23 AM Screen Shot 2021-02-26 at 9.01.22 AM
I need the connector with the pigtails coming out, but it looks to have fins coming out
Hi Rudy, thank you for your inquiry. Per your photo, and without knowing the pitch of the terminals, it looks like you have this: H1920-ND
Can verify the specs and confirm?
Yes, I think that is the one. Thank you so much for your help. By any chance do you know what type of DC power cable this is?
Screen Shot 2021-02-26 at 12.49.17 PM Screen Shot 2021-02-26 at 12.48.47 PM Screen Shot 2021-02-26 at 12.48.19 PM
Do you happen to know which df5 pin would fit?
I’m sorry, but I haven’t been able to match this one.
Are you referring to contacts to the H1920-ND?
Yes the pins that would insert inside the plug.
Or is there a possibility of buying it as a pigtail with the wires/pin inserted? I assume not.
Any of those contacts would work, and we may be able to do a custom assembly. For this you would send an email request to custom.orders@digikey.com with the contact part number and the wire gauge, length, and color.
