Product page: https://www.digikey.ca/short/9zzh0c94
Datasheet: https://www.meanwellusa.com/upload/pdf/RS-15/RS-15-spec.pdf
Description: 24V 0.625mA AC-DC standalone enclosed power supply with barrier blocks for wire-board connecting.
The mechanical specification shows a very vague dimension… 6mm wide barriers with unknown studs to hold a spade or ring crimp connector.
It could be M2.5, M3, M3.5, M4, #4, or #6 hole size.
Naturally, I would guess something in the middle, but a datasheet should usually leave zero room for interpretation.
Am I missing something here?
Reply and let me know if you can’t find a reason either so I don’t feel like I’m the only one!
