Help Identifying
I am needing help identifying this component, as you can see it is cracked and needs to be replaced.
That is a PTC Diode. Attached is the Datasheet in PDF.
HL30-050.PDF (1014.6 KB)
Thank you, I am still having trouble locating them but ill keep looking.
Thanks!
Use of the term “diode” will have one looking for quite a while, because it’s a PTC resettable fuse. Not a diode.
13-BK30-700-SZ-ND looks very similar.
Yes , I understand that, however, the manufacturer does refer to it just that way:
Now that I look over the datasheet, I see it does not appear to have any features a diode would have. I thought it was something I had never seen before. I guess there was some error in the translation. :grin:
