I am currently working on the power generation part of a 3U CubeSat, and I would like to assemble a solar array. I have an interest in the ANYSOLAR solar cells, Specifically, the SolarMDs; however, I am uncertain about the assembly and any other materials needed for assembly of the solar array. Specially, I am unsure on how to connect the solar cells in array, and what wires or materials I need to do so. Does anyone have experience or knowledge in this area and can give some guidance on any other materials needed to purchase for the assembly of the solar array, and how to connect the solar cells in series where they can be integrated into the power system of the CubeSat? Also, I do know how to solder.
Welcome to the DigiKey TechForum. Here is some good information provided by the manufacturer on circuit design, Module Circuit Design | PVEducation. I’m not familiar with what other products you may need for your application but others may be able to add information that may assist you.
Here’s an additional application note from AnySolar which I found here which might be of some help. That link also gives information on cleaning, sealing, bonding and such.
