Help to replace this transistor
Its from a Denon avr-x4500h receiver 4 channel amp board
KTC3206.pdf (438.8 KB)
Here is another picture of the npn transistor
Hello ns2_1982,
This should be a 2SC3206 transistor, but we do not carry this part number.
I also was not able to find an exact match. The closest alternate is KSC2383OTACT-ND.
These have the same pinout of Pin 1= Emitter, Pin 2= Collector, Pin 3= Base.
Please check the datasheet to verify compatibility to your application.
Thank you I appreciate this hopefully this will work out
