Hello, could someone please help identifying the type of connector(s) for these items:
Hi,
Welcome to the Digikey tech forum. Check through these options for the natural color header, make sure you verify the pin space to be sure it fits, the options I sent are 4.2mm from center pin across to center pin next to it. I wasn’t able to find a good match for the black header but check these options to see if one will match, again measure the pin spacing to narrow down the list. You can also do a close inspection of the parts to see if there are any markings that could be used to help verify a manufacturer or series.
Thank you. I’ll check them out.
