If you are looking for fuse holders for your POWR-GARD® FLNR Series Fuses from Littelfuse Inc., DigiKey has you covered. Indicated by the datasheet for POWR-GARD® Blocks and Holders, they are designed for use with the POWR-GARD® FLNR series of fuses. You will need to use the filters to narrow it down to the holder you feel works best for your application.
Applicable Part Numbers
| Fuses | |
| 5666-FLNR020.T-ND | FLNR020.T |
| 5666-FLNR025.T-ND | FLNR025.T |
| F1029-ND | FLNR015.T |
| 5666-FLNR030.T-ND | FLNR030.T |
| 5666-FLNR010.T-ND | FLNR010.T |
| 5666-FLNR6.25T-ND | FLNR6.25T |
| 1294-FLNR001.T-CHP,5666-FLNR001.T-ND | FLNR001.T |
| F1034-ND | FLNR060.T |
| 5666-FLNR012.T-ND | FLNR012.T |
| 5666-FLNR009.T-ND | FLNR009.T |
| 5666-FLNR100.V-ND | FLNR100.V |
| 5666-FLNR175.X-ND | FLNR175.X |
| 5666-FLNR125.X-ND | FLNR125.X |
| 5666-FLNR600.X-ND | FLNR600.X |
| 5666-FLNR005.T-ND | FLNR005.T |
| 5666-FLNR002.T-ND | FLNR002.T |
| 5666-FLNR040.T-ND | FLNR040.T |
| 5666-FLNR050.T-ND | FLNR050.T |
| 5666-FLNR200.X-ND | FLNR200.X |
| F1027-ND | FLNR008.T |
| 5666-FLNR045.T-ND | FLNR045.T |
| 5666-FLNR080.V-ND | FLNR080.V |
| 5666-FLNR070.V-ND | FLNR070.V |
| 5666-FLNR400.X-ND | FLNR400.X |
| 5666-FLNR17.5T-ND | FLNR17.5T |
| 5666-FLNR006.T-ND | FLNR006.T |
| 5666-FLNR003.T-ND | FLNR003.T |
| 5666-FLNR004.T-ND | FLNR004.T |
| 5666-FLNR03.2T-ND | FLNR03.2T |
| 5666-FLNR01.4T-ND | FLNR01.4T |
| 5666-FLNR03.5T-ND | FLNR03.5T |
| 5666-FLNR007.T-ND | FLNR007.T |
| 5666-FLNR04.5T-ND | FLNR04.5T |
| 5666-FLNR035.T-ND | FLNR035.T |
| 5666-FLNR01.6T-ND | FLNR01.6T |
| 5666-FLNR02.5T-ND | FLNR02.5T |
| 5666-FLNR01.5T-ND | FLNR01.5T |
| 5666-FLNR05.6T-ND | FLNR05.6T |
| 5666-FLNR07.5T-ND | FLNR07.5T |
| 5666-FLNR1.25T-ND | FLNR1.25T |
| 5666-FLNR02.8T-ND | FLNR02.8T |
| 5666-FLNR.800T-ND | FLNR.800T |
| 5666-FLNR.200T-ND | FLNR.200T |
| 5666-FLNR.300T-ND | FLNR.300T |
| 5666-FLNR.400T-ND | FLNR.400T |
| 5666-FLNR.250T-ND | FLNR.250T |
| 5666-FLNR.150T-ND | FLNR.150T |
| 5666-FLNR1.12T-ND | FLNR1.12T |
| 5666-FLNR01.8T-ND | FLNR01.8T |
| 5666-FLNR2.25T-ND | FLNR2.25T |
| 5666-FLNR.100T-ND | FLNR.100T |
| 5666-FLNR.125T-ND | FLNR.125T |
| 5666-FLNR.600T-ND | FLNR.600T |
| 5666-FLNR.500T-ND | FLNR.500T |
| 5666-FLNR090.V-ND | FLNR090.V |
| 5666-FLNR075.V-ND | FLNR075.V |
| 5666-FLNR150.X-ND | FLNR150.X |
| 5666-FLNR110.X-ND | FLNR110.X |
| 5666-FLNR350.X-ND | FLNR350.X |
| 5666-FLNR250.X-ND | FLNR250.X |
| 5666-FLNR300.X-ND | FLNR300.X |
| 5666-FLNR225.X-ND | FLNR225.X |
| 5666-FLNR450.X-ND | FLNR450.X |
| 5666-FLNR500.X-ND | FLNR500.X |
| Fuse Holders | |
| DigiKey Part Numbers | Manufacturer Part Numbers |
| 5666-LFR600301PID-ND | LFR600301PID |
| F11268-ND | LFR250302C |
| F11269-ND | LFR250603CID |
| 5666-LFR600603CID-ND | LFR600603CID |
| 5666-LFR601003CID-ND | LFR601003CID |
| 5666-LFR250602CID-ND | LFR250602CID |
| LFR600302PID-ND | LFR600302PID |
| LFR250302S-ND | LFR250302S |
| 5666-LFR250601CID-ND | LFR250601CID |
| 5666-LFR600601CID-ND | LFR600601CID |
| 5666-LFR251001CID-ND | LFR251001CID |
| LFR600303CID-ND | LFR600303CID |
| LFR251003CID-ND | LFR251003CID |
| 5666-LFR250301S-ND | LFR250301S |
| 5666-LFR250301P-ND | LFR250301P |
| 5666-LFR250301C-ND | LFR250301C |
| 5666-LFR250302P-ND | LFR250302P |
| 5666-LFR600301SID-ND | LFR600301SID |
| 5666-LFR600301CID-ND | LFR600301CID |
| 5666-LFR250303S-ND | LFR250303S |
| 5666-LFR250303P-ND | LFR250303P |
| 5666-LFR600302SID-ND | LFR600302SID |
| 5666-LFR250303C-ND | LFR250303C |
| 5666-LFR600302CID-ND | LFR600302CID |
| 5666-LFR600303SID-ND | LFR600303SID |
| 5666-LFR600303PID-ND | LFR600303PID |
| 5666-LFR600602CID-ND | LFR600602CID |
| 5666-LFR601001CID-ND | LFR601001CID |
| 5666-LFR252001C-ND | LFR252001C |
| 5666-LFR602001C-ND | LFR602001C |
| 5666-LFR604001C-ND | LFR604001C |
| 5666-LFR252003C-ND | LFR252003C |
| 5666-LFR602003C-ND | LFR602003C |
| 5666-LFR254001C-ND | LFR254001C |
| 5666-LFR256001C-ND | LFR256001C |
| 5666-LFR606001C-ND | LFR606001C |
| 5666-LFR604003C-ND | LFR604003C |
| 5666-LFR254003C-ND | LFR254003C |
| 5666-LFR606003C-ND | LFR606003C |
| 5666-LFR256003C-ND | LFR256003C |
