When looking at Fuse Holders from Littelfuse, you’ll sometimes find that there are different orderable part numbers available. For example, the part numbers listed on the datasheet for 01500274 are - 01500274Z, 01500274LXN and 01500274ZXU. What is the difference between these part numbers?
Note: Packaging information is part specific and must be confirmed from the spec sheet!
Looking at the ordering information in the datasheet, you can see that
01500274Z: this part is ordered in bulk pack of 100 pcs.
01500274LXN: this part is ordered in bulk pack of 50 pcs.
01500274ZXU: this part is order in bulk pack of 5000pcs. But please note that this part is unassembled fuseholder and UL Recognition does not apply.
Also worth noting is that this part number does not come with wire. Suffix U at the end of the number calls out Unassembled.
If you require the holders with wire leads, it’s recommended to order part numbers 01500274Z and 01500274LXN.
Applicable Part Numbers
01500274Z
01500274ZXU
01500274LXN
F1468-ND
01500274ZXU-ND
F11934-ND
