Hi, currently our small company is developing the qualification process of a small remotly controled aircraft landing gear, in this order, we need to take a measure of wheel speed in order to adjust our diferential brake system, we have a small space available for a speed sensor, do you think the honeywell 3080 vrs Speed sensor is applicable for take this measure?
Thanks
Greetings,
Unfortunately we can not give an affirmative answer to questions of this type; it is up to you to decide whether or not any particular device will satisfy your needs.
What can be said is that a device of that kind might be a reasonable option. Its principle of operation is quite simple, which is helpful for achieving a rugged and reliable result. On the other hand, the interpretation of its output may be more complex than for some other sensor types, and might not be very reliable at low speeds.
