How Do I Mount DSML-0224-12 from Delta Electronics
A frequent question we get on the DSML-0224-12 solenoid from Delta Electronics is how to mount it.
This part is able to be mounted in almost any fashion. They do not have threaded holes or mounting studs to allow you to freely use this as you see fit. Some will drill and tap holes for this or even weld it in place with the housing. Another option that may work depending on your application is our selection of VHB tape which has a high bond strength. Use the link below to view VHB tapes we currently have in stock. Choose the one that best suits your application and please review the datasheets to ensure the tape will work for your particular application.
VHB Tape | Electronic Components Distributor DigiKey
