Hi Team
Below is terminal connection discription
im need equivalent for attached picture hydrogen gas sensor
i has selected one of hydrogen gas sensor in digikey im not sure is correct or not
can please advice on my selection
Add images
Hello lechu,
Welcome to the DigiKey TechForum community.
I’m not sure what that one in the photo is exactly. There are some in stock Hydrogen sensors in link below we currently have in stock that seem similar.
Gas Sensors | Electronic Components Distributor DigiKey
Hope that helps.
Regards,
Hello Mr irfan
The gas sensor is exactly same as added inside my cart and in my list
The picture im upload you cant see the filter mesh it was below
Is the all Mq8 H2 sensor common
Interm of wiring connection?
The pocture showing terminal connection
The filter is below
This is backlite type.
This sensor is measure and detect H2 at atmospheres
The H2 iis produce from process electrolysis
By electrical chlorination systrm
The existing gas sensor 3 wire connections
5V
GRN
Signal input
The measuring showing at our system EC LCD screen display in %
I
Hello lechu,
Looking at the H2 sensors we carry, for working on 5VDC, I do not see a match to your device.
The closest option I found, was 1738-SEN0572-ND.
This is a small H2 gas sensor board, with a 3 wire hookup.
