I need a double, triple and quartet of these terminals. I could not find. Can anyone help?
For the two, three and four position plugs with sockets, left on picture, here is a web link to several that you may choose from.
Click here for web link
For the two, three and 4 position 90deg male pin headers, right on picture, here is a web link to several you may choose from
Hello arifguler, Welcome to the Forum.
With the links that John sent,
Make sure to measure the Pitch of the part. That is the Center to Center spacing. They will need to be the same for the Plug and Header. Also if you pick them out Try to stay with the same manufacturer. That may they will mate properly together. There are some Parts that are similar from other manufacturers that might not fit together properly.
If you need anything else please let us know.
