I need a RT1N241M SOT-233 transistor or sub
I need to repair a Yaesu FT-711M tranceiver. One of the components I need is a pre-biased SOT-233 package which is shown as a “RT1N241M.”
I can not find that. Does anyone know where I can order 3 or 4 pieces? Does anyone know of a substitute?
Regards, Dan
Hello w8kmx,
To help you, we need a photo of this component.
Hi Dan,
I found the specs of the RT1N241M here: RT1N241M Datasheet and Replacement, Transistor Equivalent Finder, Cross Reference. AllTransistors.com
From there I located some possible similar ones like 1727-6278-1-ND or ones in link below:
Single, Pre-Biased Bipolar Transistors | Bipolar (BJT) | Transistors | Electronic Components Distributor DigiKey
Please review these carefully and verify if they will work for your application.
Regards,
Excellent feedback. Thanks very much. It looks like 1727-6268-1-ND will work.
Regards,
Dan
Hi, Dan.
If you would like to have other alternatives, at MCC, we count with a 1 level cross:
DTC124EUA
MCC (Micro Commercial Components) DTC124EUA-TP
Best regards,
Samuel.
