I need to buy this i cant find
This is a NIHON DEMPA KOGYO Oscillator. These are the possible options that I found that might work as replacement.
thx are to small as size dont match my one is 3.4x2.5 mm
Hi homestyle.nz,
I suspect that you have a crystal rather than an oscillator, based on the markings.
It’s likely one of the these crystals from the NDK NX3225SA series.
From the NX3225SA series datasheet:
I don’t know which, if any of the options we carry is the right match for you, as they don’t give decoding info for the various options from the markings. However, some of these are designed to work with particular RF IC’s. If you know what RF IC this is next to on your circuit board, we might be able to make an educated guess as to which one would likely be the best option.
