250 volt 5 amp resister/fuse for a replacement on a generator>
Add images
Add images
Welcome to the forum.
Need to know more information,
I’m assuming it’s a 250V AC fuse that you need.
There are 98 different 250VAC 5A fuses currently in stock.
Which response speed? [fast (most common), slow, or medium (least common)]
What body type? [automotive blade, glass cartridge, or ceramic cartridge]
If a cartridge type, which size? [length, diameter]
You can add your choices in this search to narrow down the choices.
