Identification Help
I am attempting too find a three pin plug that mates with this black plastic edge connector. Any help would be appreciated. As an alternative are there any single headers that would fit over these pins that I could solder to the power supply wires?
Thank you.
Chuck
Do you have pin spacing and measurements for this part?
Hello Chuck,
I believe the receptacle is our number HR173-ND, https://www.digikey.com/short/4c88np, and the mating connector is HR1286-ND, https://www.digikey.com/short/4c88dj. Please verify the datasheet before ordering.
HR173-ND
HR1286-ND
Thanks!
Rhonda,
Thank you it appears that Jeff found the correct part.
Regards,
Chuck
Jeff,
I believe you have found it. I have oredered a couple to make sure.
Thank you for your help.
Regards,
Chuck
Hello Chuck,
Sorry, I just noticed this. The crimp contacts HR175-ND are sold separately.
Thanks!
I know, I found them and ordered 10.
Thanks
