What is this connector called? I need to order one of these to attempt a repair on this circuit board.
Measures 12mm wide, 8.5mm tall. 8 pins.
Hello bgifford,
Welcome to DigiKey’s TechForum,
Please consider part number A121810-ND
Description: Connector Header Male 10 Position 2 Row .100” Pitch 90 degree 2 wall Through Hole mount
@Troy_2808, can you advise on the correct female connector and crimp inserts for the connector? I think the correct connector is this one: 926476-5-ND, however I cannot find for sure which crimp inserts go with this female connector.
