Looking for a source for compatible pin as seen below.
Solid Pin, Gold Plated
Pin Diameter 1.9mm
Pin Length to shoulder ~14mm
Shoulder length 2.5-4mm
Welcome to the DigiKey TechForum. Dimensions are not a parameter we can search by, do you have the part number of the connector this contact is used in?
The existing pins are from Amphenol Series 44 such as 0441041000202. However, the pin suggested by Amphenol is tin plated where the ones I’m replacing are gold plated.
Thanks for the information, closest option I found is DigiKey part 889-1139-ND. This isn’t an exact match but close.
Thanks. Any insight into how a 2.0mm pin will work with a 1.9mm socket?
