I need help identifying a part or a tool to do the job. I believe I have a MIL Connector. Its use if for a vacuum chamber and need to remove two sockets so I can reattach the wires. The connector does not have any part number on it so I cannot tell what would be the proper way and tool to use to remove the sockets. From comparison it appears to be some kind of MIL connector I just cannot tell exactly and do not want to purchase an incorrect part or tool. I have a attached multiple images of the connector hoping that you can identify the part or recommend me to someone who could.
It is a 41 pin insert with 20 gauge socket inserts
I appreciate any help you can provide! If you could only recommend a tool that would also be great!
Thank You
