Dear sir
Now I try to use PADS Maker tool.
I am beginner for PCB Layout.
Then, is it possible to import a schematic netlist generated by third party tool into PADS Maker?
Thank you.
Dear sir
Thank you.
You should be able to import. Use the Import command to import Maker Schematic projectname.dnf netlist files into your design.
Here is also a great link that helps explain.
http://wiki.sdd.mentor.com/pages/viewpage.action?pageId=3146632
Robert
Hi Robert
Thank you for your reply.
I did netlist import according to the procedure.
However tool shows some error because of my OrCAD library.
I will check it.
Thank you.
If you are unable to resolve this issue please let me know the error you are getting and I can have my team look into it.
Robert
If I can not resolve this problem, I will ask you again.
Thank you.
