Hi Robert,
I followed your guide for Wandboard 2D/3D, using kernel version 4.12.0-rc1-armv7-x0 and debian-8.8-minimal-armhf-2017-05-11.
I also installed xserver-xorg-input-evdev and x11-server-utils.
I connected the Sabre board to an HDMI monitor; i’m able to see the freescale logo when boot starts, and the console when starts rootfs.
but if try to run Xorg, the screen became blanc and it seems like the system is crashed, because I’m not able to come back to arm@debian on the debug uart.
The file Xorg.0.log does not report errors. The content is:
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 77.233] X Protocol Version 11, Revision 0
[ 77.233] Build Operating System: Linux 3.16.0-0.bpo.4-armmp-lpae armv7l Debian
[ 77.233] Current Operating System: Linux arm 4.12.0-rc1-armv7-x0 #1 SMP Wed May 17 13:07:20 CEST 2017 armv7l
[ 77.233] Kernel command line: console=ttymxc0,115200 root=PARTUUID=613f3307-01 ro rootfstype=ext4 rootwait video=HDMI-A-1:1920x1080@60e
[ 77.234] Build Date: 11 February 2015 01:18:06AM
[ 77.234] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 77.234] Current version of pixman: 0.32.6
[ 77.234] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 77.234] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 77.234] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu May 18 16:43:51 2017
[ 77.236] (==) Using config file: “/etc/X11/xorg.conf”
[ 77.236] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 77.239] (==) ServerLayout “Builtin Default Layout”
[ 77.239] () |–>Screen “Builtin Default fbdev Screen 0” (0)
[ 77.239] () | |–>Monitor “Builtin Default Monitor”
[ 77.246] () | |–>Device “Builtin Default fbdev Device 0”
[ 77.246] (==) Automatically adding devices
[ 77.246] (==) Automatically enabling devices
[ 77.246] (==) Automatically adding GPU devices
[ 77.261] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 77.261] Entry deleted from font path.
[ 77.262] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 77.262] Entry deleted from font path.
[ 77.262] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 77.262] (WW) The directory “/usr/share/fonts/X11/Type1” does not exist.
[ 77.262] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 77.262] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 77.262] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 77.262] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 77.262] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 77.262] (II) Loader magic: 0x7f74df18
[ 77.262] (II) Module ABI versions:
[ 77.262] X.Org ANSI C Emulation: 0.4
[ 77.262] X.Org Video Driver: 18.0
[ 77.262] X.Org XInput driver : 21.0
[ 77.262] X.Org Server Extension : 8.0
[ 77.266] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 77.267] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 77.268] (II) no primary bus or device found
[ 77.268] falling back to /sys/devices/soc0/display-subsystem/drm/card1
[ 77.268] (II) LoadModule: “glx”
[ 77.270] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 77.347] (II) Module glx: vendor=“X.Org Foundation”
[ 77.347] compiled for 1.16.4, module version = 1.0.0
[ 77.348] ABI class: X.Org Server Extension, version 8.0
[ 77.348] (==) AIGLX enabled
[ 77.348] (II) LoadModule: “armada”
[ 77.350] (II) Loading /usr/lib/xorg/modules/drivers/armada_drv.so
[ 77.356] (II) Module armada: vendor=“X.Org Foundation”
[ 77.356] compiled for 1.16.4, module version = 0.0.0
[ 77.356] Module class: X.Org Video Driver
[ 77.356] ABI class: X.Org Video Driver, version 18.0
[ 77.356] (II) armada: Support for Marvell LCD Controller: 88AP510
[ 77.356] (II) armada: Support for Freescale IPU: i.MX6
[ 77.357] (–) using VT number 2
[ 77.376] (II) armada(0): Added screen for KMS device /dev/dri/card1
[ 77.376] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 77.376] (II) armada(0): hardware: imx-drm
[ 77.376] (II) armada(0): Creating default Display subsection in Screen section
"Builtin Default fbdev Screen 0" for depth/fbbpp 24/32
[ 77.376] () armada(0): Depth 24, (–) framebuffer bpp 32
[ 77.376] (==) armada(0): RGB weight 888
[ 77.376] (==) armada(0): Default visual is TrueColor
[ 77.377] (II) Loading sub module “etnadrm_gpu”
[ 77.377] (II) LoadModule: “etnadrm_gpu”
[ 77.377] (II) Loading /usr/lib/xorg/modules/drivers/etnadrm_gpu.so
[ 77.385] (II) Module Etnaviv GPU driver (DRM): vendor=“X.Org Foundation”
[ 77.385] compiled for 1.16.4, module version = 0.0.0
[ 77.385] ABI class: X.Org ANSI C Emulation, version 0.4
[ 77.418] (II) armada(0): Output HDMI1 using monitor section Builtin Default Monitor
[ 77.419] (II) armada(0): Output LVDS1 has no monitor section
[ 77.453] (II) armada(0): EDID for output HDMI1
[ 77.453] (II) armada(0): Manufacturer: PHL Model: c0cf Serial#: 14923
[ 77.453] (II) armada(0): Year: 2016 Week: 7
[ 77.453] (II) armada(0): EDID Version: 1.3
[ 77.453] (II) armada(0): Digital Display Input
[ 77.453] (II) armada(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 77.453] (II) armada(0): Gamma: 2.20
[ 77.453] (II) armada(0): DPMS capabilities: Off
[ 77.453] (II) armada(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 77.453] (II) armada(0): First detailed timing is preferred mode
[ 77.453] (II) armada(0): redX: 0.633 redY: 0.351 greenX: 0.322 greenY: 0.630
[ 77.454] (II) armada(0): blueX: 0.152 blueY: 0.050 whiteX: 0.313 whiteY: 0.329
[ 77.454] (II) armada(0): Supported established timings:
[ 77.454] (II) armada(0): 720x400@70Hz
[ 77.454] (II) armada(0): 640x480@60Hz
[ 77.454] (II) armada(0): 640x480@67Hz
[ 77.454] (II) armada(0): 640x480@72Hz
[ 77.454] (II) armada(0): 640x480@75Hz
[ 77.454] (II) armada(0): 800x600@60Hz
[ 77.454] (II) armada(0): 800x600@75Hz
[ 77.454] (II) armada(0): 1024x768@60Hz
[ 77.454] (II) armada(0): 1024x768@75Hz
[ 77.454] (II) armada(0): 1280x1024@75Hz
[ 77.454] (II) armada(0): Manufacturer’s mask: 0
[ 77.454] (II) armada(0): Supported standard timings:
[ 77.454] (II) armada(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 77.454] (II) armada(0): #1: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 77.454] (II) armada(0): #2: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 77.454] (II) armada(0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 77.455] (II) armada(0): #4: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 77.455] (II) armada(0): #5: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 77.455] (II) armada(0): Supported detailed timing:
[ 77.455] (II) armada(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 77.455] (II) armada(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 77.455] (II) armada(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 77.455] (II) armada(0): Serial No: ZV01607014923
[ 77.455] (II) armada(0): Monitor name: PHL 223V5
[ 77.455] (II) armada(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 77.455] (II) armada(0): clock: 27.0 MHz Image Size: 477 x 268 mm
[ 77.455] (II) armada(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 77.455] (II) armada(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 77.456] (II) armada(0): Supported detailed timing:
[ 77.456] (II) armada(0): clock: 74.2 MHz Image Size: 477 x 268 mm
[ 77.456] (II) armada(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 77.456] (II) armada(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 77.456] (II) armada(0): clock: 27.0 MHz Image Size: 477 x 268 mm
[ 77.456] (II) armada(0): h_active: 720 h_sync: 732 h_sync_end 796 h_blank_end 864 h_border: 0
[ 77.456] (II) armada(0): v_active: 576 v_sync: 581 v_sync_end 586 v_blanking: 625 v_border: 0
[ 77.456] (II) armada(0): Number of EDID sections to follow: 1
[ 77.456] (II) armada(0): EDID (in hex):
[ 77.456] (II) armada(0): 00ffffffffffff00410ccfc04b3a0000
[ 77.456] (II) armada(0): 071a010380301b782a3935a25952a127
[ 77.456] (II) armada(0): 0c5054bd4b00d1c09500950fb30081c0
[ 77.456] (II) armada(0): 818001010101023a801871382d40582c
[ 77.457] (II) armada(0): 4500dd0c1100001e000000ff005a5630
[ 77.457] (II) armada(0): 31363037303134393233000000fc0050
[ 77.457] (II) armada(0): 484c2032323356350a202020000000fd
[ 77.457] (II) armada(0): 00384c1e5311000a2020202020200110
[ 77.457] (II) armada(0): 020322f14f0102030506071011121314
[ 77.457] (II) armada(0): 15161f04230917078301000065030c00
[ 77.457] (II) armada(0): 1000023a801871382d40582c4500dd0c
[ 77.457] (II) armada(0): 1100001e8c0ad08a20e02d10103e9600
[ 77.457] (II) armada(0): dd0c11000018011d007251d01e206e28
[ 77.457] (II) armada(0): 5500dd0c1100001e8c0ad09020403120
[ 77.457] (II) armada(0): 0c405500dd0c11000018000000000000
[ 77.457] (II) armada(0): 0000000000000000000000000000004d
[ 77.457] (II) armada(0): Printing probed modes for output HDMI1
[ 77.457] (II) armada(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 77.458] (II) armada(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 77.458] (II) armada(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 77.458] (II) armada(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 77.458] (II) armada(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 77.458] (II) armada(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 77.458] (II) armada(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 77.458] (II) armada(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 77.458] (II) armada(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 77.458] (II) armada(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 77.458] (II) armada(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 77.458] (II) armada(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 77.458] (II) armada(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 77.458] (II) armada(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 77.458] (II) armada(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 77.459] (II) armada(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 77.459] (II) armada(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 77.459] (II) armada(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 77.459] (II) armada(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 77.459] (II) armada(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 77.459] (II) armada(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 77.459] (II) armada(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 77.459] (II) armada(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 77.459] (II) armada(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 77.459] (II) armada(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 77.459] (II) armada(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 77.459] (II) armada(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 77.459] (II) armada(0): EDID for output LVDS1
[ 77.460] (II) armada(0): Printing probed modes for output LVDS1
[ 77.460] (II) armada(0): Modeline "1024x768"x60.0 65.00 1024 1064 1124 1344 768 775 785 806 (48.4 kHz eP)
[ 77.460] (II) armada(0): Output HDMI1 connected
[ 77.460] (II) armada(0): Output LVDS1 connected
[ 77.460] (II) armada(0): Using exact sizes for initial modes
[ 77.460] (II) armada(0): Output HDMI1 using initial mode 1024x768
[ 77.460] (II) armada(0): Output LVDS1 using initial mode 1024x768
[ 77.460] (II) armada(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 77.460] (==) armada(0): DPI set to (96, 96)
[ 77.460] (II) Loading sub module “fb”
[ 77.460] (II) LoadModule: “fb”
[ 77.460] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 77.469] (II) Module fb: vendor=“X.Org Foundation”
[ 77.469] compiled for 1.16.4, module version = 1.0.0
[ 77.469] ABI class: X.Org ANSI C Emulation, version 0.4
[ 77.471] (==) Depth 24 pixmap format is 32 bpp
[ 77.492] (==) armada(0): Backing store enabled
[ 77.492] (==) armada(0): Silken mouse enabled
[ 77.492] (–) armada(0): Vivante GC320 GPU revision 5007 (etnaviv) 2d PE2.0
[ 77.493] (II) armada(0): [DRI2] Setup complete
[ 77.493] (II) armada(0): [DRI2] DRI driver: etnaviv
[ 77.493] (II) armada(0): direct rendering: DRI2 enabled
[ 77.493] () armada(0): direct rendering: DRI3 disabled
[ 77.498] (II) armada(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 77.499] (==) armada(0): DPMS enabled
[ 77.499] (==) armada(0): hotplug detection enabled
[ 77.499] (II) armada(0): etnaviv: Xv: using YUY2 format intermediate YUV target
[ 77.546] (–) RandR disabled
[ 77.595] (II) SELinux: Disabled on system
[ 78.799] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 78.800] (II) AIGLX: enabled GLX_ARB_create_context
[ 78.800] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 78.800] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 78.800] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 78.800] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 78.800] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 78.800] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 78.800] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 78.802] (II) AIGLX: Loaded and initialized etnaviv
[ 78.802] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 78.811] (II) armada(0): etnaviv: A8 target not supported
[ 78.812] (II) armada(0): Setting screen physical size to 270 x 203
[ 79.083] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[ 79.083] () gpio-keys: Applying InputClass “evdev keyboard catchall”
[ 79.083] (II) LoadModule: “evdev”
[ 79.087] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 79.097] (II) Module evdev: vendor=“X.Org Foundation”
[ 79.097] compiled for 1.16.0, module version = 2.9.0
[ 79.097] Module class: X.Org XInput Driver
[ 79.097] ABI class: X.Org XInput driver, version 21.0
[ 79.097] (II) Using input driver ‘evdev’ for ‘gpio-keys’
[ 79.097] () gpio-keys: always reports core events
[ 79.097] () evdev: gpio-keys: Device: “/dev/input/event0”
[ 79.098] (–) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 79.098] (–) evdev: gpio-keys: Found keys
[ 79.098] (II) evdev: gpio-keys: Configuring as keyboard
[ 79.098] () Option “config_info” “udev:/sys/devices/soc0/gpio-keys/input/input0/event0”
[ 79.098] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 6)
[ 79.098] () Option “xkb_rules” “evdev”
[ 79.098] () Option “xkb_model” “pc105”
[ 79.098] (**) Option “xkb_layout” “us”
and nothing more…
Do you have any suggestions?
Regards,
Jeanluc
