In what unit do you order W2628B-1000-ND?
I found this hook-up wire W2628B-1000-ND, if I order 1, what will I get, 1 foot, 1 meter och 1 spool?
Hello @hakan.vikstrom
Welcome to the community!
Part 2671/28BK‑1000 is available in two different quantity options:
  • If you enter quantity 1, it is supplied as 1 foot of wire.
    (DigiKey part number: 49-2671/28BK-1000-DS-ND)
  • If you order 1000 foot, which is the manufacturer’s standard package, (DigiKey part number W2628B‑1000‑ND).
You can simply enter the required length in foot.
I suspected that… it’s not at all clear when ordering, is it possible to add that info? (I have seen it on other cables)
Hello hakan.vikstrom,
I have reported this suggestion so that W2628B-1000-ND would align with other digi-spool wires. Thank you for the feedback.
