Question about ordering with Digi-Spool
------Question for 30-00686 Please Put your question below------
If I want to order a lenght of 20m and I order a quantity of 20, how can I know if DigiKey now cuts 20 feet or 20 meters?
Because it says that if I order Digi-Spool, I have to order either in feet or meters, but I can’t select that anywhere.
Thanks for reading and hopefully answering!
Welcome to the TechForum!
Which part number are you looking at mic.hunziker ? We do have parts that can be continuous length and different part numbers indicate feet, meters or inches even so if you could let me know the part I can let you know.
Thank you
Ryan
Thank you for your reply. The part number is: T1332-1-ND
I see that the T1332-1-ND was a set length of 3.28’ long but is discontinued. I could cross this into another option if that could work ? and how long are you needing for the length ?
Thank you
Ryan
I did find this one that is in meters per 1 ordered and it is part 839-30-00686-ND.
30-00686 Tensility International Corp | Cables, Wires | DigiKey
Oh yes that’s what I meant. How do you know that it’s ordered per meter?
The Detail description calls out to “Enter Number of Meters in Order Quantity”
