------Question for 2902997 Please Put your question below------
Help/ Ideas finding a industrial Din rail mount 24VAC Output power Supply to power some 24VAC CCTV Cameras/Housings
I was able to gather a good link of options that match your parameters mentioned. These are stocking options as of now.
Industrial, DIN Rail Power Supplies | Electronic Components Distributor DigiKey
Thank you
Ryan
Thanks Ryan for that List, However i need the output to be 24VAC not DC the input is standard 120vac plugged into outlet is there a Din rail mount DC to AC converter module or somthing that you know about i cant seem to find anything in 24vac output that’s industrial Din Mount.
I do not see that we have any DIN Rail mounted AC/AC step down power supplies. All I can find is 120VAC Primary to 24VAC Secondary Chassis mount power transformers. Take TCT40-01E07K-B for example.
