IPV-67121-B photo shows a nut. The drawing and text never mentions if the nut is included.
Thank you for conacting the Technical forum. Yes. The nut will be included per the drawing.
The drawing does not show the nut. Only the photo.
You receive exactly what is on the photo on our webiste. The link of the Bu website shows this also. The just call it an o-ring washer for sealing. IP67 Air and Moisture Vent, M12*1.5, 0.71 Inches Dia., Black IPV-67121-B - Bud Industries . That is the part that I am assuming you are talking about.
Thanks. It was a little confusing.
I know. Not a problem. I would rather you ask prior to ordering than to get something that you would not be able to use.
