Welcome to the DigiKey TechForum. Typically, PMICs charge LiPo and Lithium-Ion batteries using the CC-CV method. The battery gets charged with a constant current until the cell reaches its maximum voltage. From then on, the charger gradually decreases the charge current until the battery is fully charged. Modern charge ICs apply a few more steps to the process to increase safety. These ICs monitor the cell temperature and have a programmable cut-out function that stops charging the cell after a pre-set period.
It has a maximum discharge current of 3.9 A, but a maximum charge current of 1.6 mA. This comes with several stipulations/cautions such charging at temperature extremes. There is also a cycle life that is specificized at significantly lower charge and discharge current when compared to maximums. The implication is that lower currents prolong battery life.
