I have an idea to read a DHT11 sensor through this development kit/board and make a c++ program to read and store the value inside the mobile phone. Thank you very much in advance.
Suryadi
Suryadi
Hi suryadi,
Welcome to the Tech Forum!
Unfortunately, there is no board utilizing a DHT11 sensor which has a USB-C interface. All of the boards we carry with the DHT11 sensor on board just have connectors or pins to pass the power, ground, and the proprietary serial signal to a controller board, which would need to be programmed to decode that signal.
I would suggest, as an alternative, that you might consider trying the Sensirion SHT4X SMART GADGET. It uses a Sensirion SHT40 humidity and temperature sensor, and it can transmit it’s data via Bluetooth to either an Android or IOS-based phone.
Here’s the link to the user’s guide. And here’s the product page with more information about it.
