Is this sensor marine grade?
------Question for SEN-11050 Please Put your question below------
I need to order these temperature probes for use in a marine environment. Can I do that, or will the materials corrode?
Greetings,
It’s really more a question of whether or not the devices’ performance and longevity will satisfy your expectations when used in such an environment.
The rubber/polymer/epoxy materials from which the device is assembled are indeed moisture resistant, and not subject to “corrosion” per-se, however as with all such materials, they will degrade in their own characteristic fashion with prolonged exposure to moisture, sunlight, mechanical stresses, etc.
Importantly, it should be noted that the supplier is a purveyor of goods targeting the hobby and educational markets. As such, this item is not characterized for tolerance to environmental exposure, and carries no warranty in regard to such.
While you are free to use it wherever and however you like, you’re also expected to live with whatever results you get, be they good, bad, or otherwise.
