IT2 Diode Rectifier Replacement
Hi,
I’m trying to find a suitable single through hole diode replacement for a Taiwan Semi diode. Part is obsolete and a search brings up no exact match, so I am wondering what would be compatible. Must be same two hole package. For a Casio keyboard.
1T2.pdf (86.6 KB)
Thank you for your inquiry. I am unable to find an exact match to offer as not all parameters are searchable part HER102GA0GCT-ND is a possible cross. You can check the datasheet to verify for your application.
Ok, thank you. That looks like it should work.
Best,
-A
