KCH30A15 replacement
I’m needing a replacement or compatible part for a KCH30A15 I’ll include the datasheet.
KCH30A15.PDF (54.8 KB)
Hello TechMonkey,
Thank you for including the Datasheet.
The closest alternate is 497-3553-5-ND.
This one can handle 200V, 30A (original is 150V, 30A).
Same case size and pin arrangement.
Please check the datasheet for compatibility.
Thanks for the response, I’ll check it and see if it works.
