We currently use the M6-157-427 Brady label in our production. Our client has requested for a UL certified Label. I saw that there’s a UL certified version of this Label itself.
- Can I know if there’s a physical difference between the normal one and the UL certified version of it?
- Is there a different MPN for the UL certified version and if so how can I order it from DigiKey.
Hi @sahan.g
The M6-157-427 label is available in a UL-recognized B-427 version. And the manufacturer does not specify a separate part number for the UL-recognized version in the available documentation. Instead, they instruct customers to state the UL requirement when placing the order, so the appropriate UL-recognized material can be supplied.
Regarding physical differences, the documentation does not indicate any differences in material construction or dimensions between the standard and UL-recognized versions. Both are described as B-427 self-laminating vinyl labels. *B-427.doc
Hi Aayushi,
Thank you for your response.
I saw the section which you have mentioned, in the data sheet, prior to me reaching DigiKey Tech Forum. However, since we are a company in Sri Lanka, we are unable to clarify and order directly from Brady.
So as you have mentioned, we are to specify the UL requirement at the point of order. And since we are purchasing this material from you (DigiKey), kindly inform me how can we order it from you.
Thank you again for your support!
Hello @sahan.g
You should mention your requirements in the order notes when placing your order. Our team will review your request and let you know whether a part meeting your requirements is available.
For order-related inquiries, you can contact your regional sales team Help and Support | DigiKey
