UL certificate
------Question for LST1-01F06-4070-00 Please Put your question below------
Hello, need UL certificate for 1672-1135-ND. How could we get it?
Hello @jurgita
Welcome to TechForum Community!
We do not supply UL certificates for the parts we carry.
If the part is UL certified, it would typically have a UL file number, which allows you to request or verify the certificate directly through www.ul.com.
where I can see this UL file number?
This information is usually listed on the manufacturer’s website or in the datasheet, including whether the part is UL certified. However, I wasn’t able to find this detail.
@jurgita
For the LED module it may be that it is not a finished enough item type to be able to get UL certification.
