Hi,
We would like to check whether part number SS-60000-010 is still UL certified.
We purchased this part from you in December 2025. However, we recently noticed that the UL certification is no longer shown in the latest documentation .
Could you please confirm the current certification status and advise if there have been any change s? Could you also provide the latest UL certification documents for our reference?
I do not see that the datasheet/drawing for SS-60000-010 indicates the part is UL Certified. The datasheet for this product has not changed since a revision in 2019.
Hello sunnie.keng,
Welcome to the TechForum. Datasheet has part being made of UL-94 Thermoplastic I have requested more information from the manufacturer will post any information when received.
The reply from the manufacturer is - It is under UL file# E132408. they sent the link to the PDF.
E132408-19900730-CertificateofCompliance-UL.pdf (232.6 KB)
Hi Quinn,
The information below was found on the UL website, and it shows that the certification expired on 2025/12/19. Our UL auditor has also raised this as a finding. Could you please provide the latest valid document?
A last updated date does not inherently mean the certificate has expired. That is just when the information was last updated.
Could you please advise if any other brands have equivalent parts with UL certification ?
I am sorry, UL certification is not a searchable parameter in our system.
