This article is part of a guided learning series on building and analyzing User-Defined Function Blocks (UDFBs).
Canonical Article: Building a User-Defined Function Block (UDFB) Using Siemens TIA Portal
Learning Companion (Q&A): Explore All Questions
You are reading: Question 7
Construct a graphical bubbles and arrows representation of the featured state machine. Ref: FSM State Diagrams
Answer
At a minimum, the sketch shall include:
- 5 named states
- Outputs associated with each state
- Transition out of each state (e.g., there are three possible transitions from state closing)
- Four lines leading to the fault state
- A reset line leading from fault to opening state
- All transition lines should identify the contrition associate with the transition.
Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey
