LD UDFB Guided Learning Q09: – Identify the implicit one shot in a state machine
This article is part of a guided learning series on building and analyzing User-Defined Function Blocks (UDFBs).
:pushpin: Canonical Article: Building a User-Defined Function Block (UDFB) Using Siemens TIA Portal
:blue_book: Learning Companion (Q&A): Explore All Questions
You are reading: Question 9
Identify the implicit one shot in a state machine.
Answer
An implicit one shot occurs on every state transition. Consider the second branch of Figure 3 which activates on a fault when the motor starter fails to close within timClose. The timer output will be high for one and only one program cycle scan. The fact that we move to a new state ensures that the timer will reset on the next scan.
With regard to a state machine, this is an important consideration when we want things to occur once, and only once, on the state transitions. As example is the S_MOVE which is only activated for a single program scan.
:writing_hand: Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey
