This article is part of a guided learning series on building and analyzing User-Defined Function Blocks (UDFBs).
Canonical Article: Building a User-Defined Function Block (UDFB) Using Siemens TIA Portal
Learning Companion (Q&A): Explore All Questions
You are reading: Question 15
Modify the state machine to drive a dual-coil DCV.
Clarification
A pneumatic or hydraulic Directional Control Valve (DCV) requires a state machine similar to the featured motor starter.
Answer
This is left as a design exercise for advanced students.
To get started, let’s assume a dual-coil DCV with magnetic detection sensors for full cylinder extension and retraction.
- Use descriptive state names: retracted, extending, extended, retracting, and fault.
- Incorporate both the extended and retracted sensors into the UDFB:
xSenExtendedis monitored for states extending and extended.xSenRetractedis monitored for states retracting and retracted.
- Add appropriate time delays to account for the slower physical motion of the pneumatic or hydraulic cylinder.
Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey
